Start external application
This forum is unmoderated!
mixmog
Post by mixmog »
I'd like PF to start an external application when it loads, using a command. Is this possible?
Re: Start external application
Yes. See the control commands in the Appendix of the user manual. EXEC_...
mixmog
Post by mixmog »
I see that it would be an exec command, the question is, which one.
EXEC_COMMAND_FILE looks to be most likely, but the description seems to indicate that this command would only execute further PF commands.
Please can you clarify which command I should use to start a .bat or .exe?
Maybe you find an EXEC command with the word SHELL in its name...
Have you found it?
If not, look at EXEC_SHELL_COMMAND, that's the command to start an external app from within ProppFrexx.
