No cartwall in demo mode?
I'm testing the latest download of Proppfrexx with D&R Airlite.
Everything seems to work properly (3 Players + GPIO automation) but I can't activate any cartwall.
I guess I've configured everything as described. Please help.
Best regards,
Ramses.
Best regards,
Ramses.
Re: No cartwall in demo mode?
The cartwall should also work in Demo mode.
What exactly is not working?
Is it not visible? Can you play it manually via a mouse click?
Or is only the D&R remoteing not triggering the cartwall?
It is not visable and D&R remote doesn't trigger cartwall. Players are triggered perfectly.
If it is not visible, you must have moved it to an none visible location when re-arranging the windows.
You can reset the layout in the general settings. Section Look and Feel.
If D&R is still not triggering it, you should contact the provider of the D&R preset which you used, as it is in general working fine with many users.
installed on another PC without the Airlite Github files and then I see the cartwall without any issue. So, there might be something wrong when I use it together with Airlite configs?
Ramses
Ramses
I don’t think so, as the D&R settings doesn’t impact the layout. But you can now try it on the new PC. And even try what I suggested above.
