GPIO Client error
Re: GPIO Client error
radio42 wrote: ↑17 Oct 2021 13:29 There seems to have been an update issue with the latest version, e.g. your GPIO Client application was not gracefully shutdown beforehand or some components could not be updated completely. Or you installed both
The debug log reports a version of a needed Zyan.Communication.dll of 2.13.0.0 - but the correct version needs to be 2.15.0.0!
So please check or update those manually.
I have attached the correct version here:
http://www.proppfrexx.radio42.com/downl ... on.dll.zip
Else you can also re-install the latest official version...
And make sure, that all instances of ProppFrexx ONAIR and the GPIO Client use the same version.
i installed and Replaced the File noting happend
Replaced file only notings Changed
Then I need to check, if something else in the setup/installation is broken?!
I have the same problem with the D&R WEBSTATION. The GIOP communicates with the web station. But the signal does not go to Proppfrexx On Air. When I click on the connection button between GIOP and Proppfrexx, the slider moves in the background when I click on it with the mouse
There seems to be a general problem with the latest build and an update to the remoting lib I am using. I need to correct the latest build and provide an update for that! This will happen asap...
A new version 4.2.6.6 is available, which should fix the remoting issue (Zyan) with the latest build!
worked d & r communicates again via GIOP with Proppfrexx Thank you Bernd
Yes problem solved , everything works fine .
Thanks Bernd for the fix.
