windows operating system
owienk
Post by owienk »
We want to buy a new server for our proppfrexx radio automation. Now we have a choice of several OS versions. What do you recommend or are there advantages and/or disadvantages of a certain OS version?
We have a choice between:
Windows 10 PRO, Windows 11 PRO
Windows Server 2019 STD or Windows Server 2022 STD.
Re: windows operating system
All of them would work equally good.
The difference is mainly about support and maintenance.
I would personally maybe go for the Win11 or Server2022 version, as those are supported for a longer time.
Audio processing is almost the same on both.
owienk
Post by owienk »
Oke. Thanks.
