MODStream behavior with overlays
Re: MODStream behavior with overlays
So just to be to be clear... you start the MODStream at e.g. 10:07...and the overlays at 11:00 are all of a sudden not suppressed anymore - but the MODStream is still playing at that time?
Maartenvn
Post by Maartenvn »
Yes, the MODStream is still playing when the overlay is not suppressed. When the overlay starts playing the MODStream audio is muted but remains in “Playing” status.
I have provided a v4.3.4.4-beta version - so please 'Check for Beta-Versions...' to update.
I have maybe found the possibility why the MODStream Suppress Overlay option sometimes fails when in parallel a program/playlist change happens.... so give it a try.
THX
Maartenvn
Post by Maartenvn »
Thank you! I will test the beta version. I will keep a MODStream running for a few hours and will get back to you with the results!
Maartenvn
Post by Maartenvn »
I left a MODStream on for 12 hours and during that period all overlays where successfully suppressed. So everything works as expected now, thank you!
Cool. Then I guess we have found the solution.
Thx
