Macbook
This forum is unmoderated!
Majesty
Macbook
Post by Majesty »
Soon I will have my first Mac Book Pro(13 or 15 inch) with Retina display.
I see no proppfrexx support for Mac.
* How about that, Bernd?
* Can a 13 inch monitor handle proppfrexx?
Thanks
TheoOrl45
Re: Macbook
Post by TheoOrl45 »
Use virtualbox to virtualize a windows operating system. And run proppfrexx into it...:-)
Theo, from France.
Re: Macbook
As Theo suggests, using e.g. Win7 on a MAC Book should be possible (a couple of users are doing so).
But I am affraid, that there will be no native support for the MAC OSx, as there are too many Windows dependencies, e.g. ProppFrexx uses the .Net Framework, plus various libraries, which simply doesn't exist for the MAC.
If a 13'' monitor is sufficient is up to you. It might be a bit small for all the windows/panels, but that is up to your demands.
Majesty
Re: Macbook
Post by Majesty »
You didn't mention windows 8.
I will install windows 8 on the MacBook Pro 15" and not windows 7.
Or would you advise windows 7?
Re: Macbook
I just said e.g. Win7...Win8 would also be fine.
szal77
Re: Macbook
Post by szal77 »
I heard someone say that ProppFrexx runs even better on Win8 than on Win7.
