Some UI Questions
szal77
Some UI Questions
Post by szal77 »
Good evening,
I just found out by accident that I can switch to the mixer window, which I have undocked, moved to the bottom of the screen, and then minimized, by pressing Ctrl+M. Now I thought that it would be great if I could minimize the mixer again by pressing the same key combination once more.
On a related note: Can the “slide” effect be turned off? If not, would it be possible for a future version to have it automatically disabled when UI performance is set to Low?
Thank you for your consideration.
Greetings
Sven
Re: Some UI Questions
Yes, this behaviour (your suggestions) has now been added/changed in the new v3.0.11.34.
szal77
Post by szal77 »
The slide effect for detached and minimized windows is NOT disabled with UI performance set to Slow in 3.0.11.35.
But the key combo for hiding the mixer window again works fine. Thank you.
