Unable to open Overlay scheduler
Farbo
Post by Farbo »
Hi Bernd.
I am unable to open Overlay Scheduler. And for example until I manually reload or rescan script libraries I am unable to open normal Scheduler too.
What is worng?
Peter
Re: Unable to open Overlay scheduler
That sounds strange - I can not reproduce that issue here.
Have you recently changed anything within your setup/configuration, e.g. added new libs, added new overlays, scripts etc.?
That sounds like ProppFrexx is still loading its libraries resp. tries to initialize?
Have you tried rebooting your machine...?
Farbo
Post by Farbo »
I made no changes to anything. Just updates of PF.
I realized PF is busy (red indicator) after start-up but no rescan or reload is done.
Peter
Is the red busy indicator going 'away' after some time?
However, at startup the following is performed (which also keeps the busy indicator 'red'):
a) Loading/Checking of all VSTs dll-files defined in the VST folder
a) Loading/Checking of all Winamp dll-files defined in the Winamp folder
a) Loading of your current mixer settings
a) Loading of all Media-Libraries (playlist, folders etc.)
a) Loading of all Cartwall-Libraries (playlist, folders etc.)
a) Loading of all Script-Libraries (playlist, folders etc.)
a) Rescan of Folder-Libs (at startup, if defined)
So, it looks like that one of these tasks do effectively fail, got stuck or doesn't return.
The main status bar should actually tell you a bit more where it might 'hang'.
Farbo
Post by Farbo »
Yes, but there is nothing showing up in the status bar. Otherwise I would know what is going on. :-(
Peter
That is really odd.
The only way to determine what is going wrong is to subsequently disable all the above features - as it seems somehow related to some broken settings in your config...
As such please perform the following:
- close PF
- disable a single feature (see below for details)
- restart PF
...see if that changes things...
If it does NOT:
- close PF
- re-enable the feature
- disable a next feature
- restart PF
a) Loading/Checking of all VSTs dll-files defined in the VST folder:
Disable: Rename your VST folder via the Windows Explorer.
Re-Enable: Rename your VST folder back to its original name.
b) Loading/Checking of all Winamp dll-files defined in the Winamp folder
Disable: Rename your Winamp folder via the Windows Explorer.
Re-Enable: Rename your Winamp folder back to its original name.
c) Loading of your current mixer settings
Disable: Rename your currently used '.mixer' file within the ProppFrexx AppUserData folder (e.g. 'Default.mixer')
Re-Enable: Rename your .mixer file back to its original name.
d) Loading of your current layout settings
Disable: Rename your currently used '.layout' file within the ProppFrexx AppUserData folder (e.g. 'ProppFrexx ONAIR.layout')
Re-Enable: Rename your .layout file back to its original name.
d) Loading of all Media-Libraries (playlist, folders etc.)
Disable: Rename the 'ProppFrexx ONAIR.medialibs' file within the ProppFrexx AppUserData folder
Re-Enable: Rename it back to 'ProppFrexx ONAIR.medialibs'.
e) Loading of all Cartwall-Libraries (playlist, folders etc.)
Disable: Rename the 'ProppFrexx ONAIR.cardwalllibs' file within the ProppFrexx AppUserData folder
Re-Enable: Rename it back to 'ProppFrexx ONAIR.cardwalllibs'.
f) Loading of all Script-Libraries (playlist, folders etc.)
Disable: Rename the 'ProppFrexx ONAIR.scriptlibs' file within the ProppFrexx AppUserData folder
Re-Enable: Rename it back to 'ProppFrexx ONAIR.scriptlibs'.
g) Program Scheduler:
Disable: Rename the 'ProppFrexx ONAIR.calendar' file within the ProppFrexx AppUserData folder
Re-Enable: Rename it back to 'ProppFrexx ONAIR.calendar'.
h) Overlay Scheduler:
Disable: Rename your configured Advert-Storage-Path folder
Re-Enable: Rename it back to its original name
NOTE/CAUTION:
Before making any of the above change - please make a complete copy of all the above referenced folders!
To make a quick test then you might also create a complete copy of the ProppFrexx AppUserData folder and then rename this folder - this would start PF with all default settings (fresh from scratch)...if PF then starts smooth, try adding in all the original settings...always closer/restart PF in between.
Any news?
Farbo
Post by Farbo »
Sorry Bernd. I did not have time to try it. Close this issue. Thank you.
Peter
