Midi Control Help
This forum is unmoderated!
Re: Midi Control Help
Try leaving the 'Status' to 0!
EXEC_SEND_MIDI_SHORTMSG 0xB0|0|${outputmixer1volume}
Note, that ${outputmixer1volume} references your 1st output mixer.
Yvetiboom
Post by Yvetiboom »
If I summary :
EXEC_SEND_MIDI_SHORTMSG 0xB0|0|${CONDA}
(In Eventcommand / on fader for player 1)
(I'm sorry to disturb you as I really try to understand your system.)
Yvetiboom
Post by Yvetiboom »
Yes I discover :geek:
I just want my BCF fader move when the fader ProppFrexx (Mixer output) and touch the software.
Because the problem is that I put an autostart on faders and if it is not down to his problem arises after the song.
And what event are you using?
Are you using the events commands when you right-click on the mixer-channel name and then select "Edit Control Commands Events..." and then select the 'OnFader' entry?
And then please try the following command:
EXEC_SEND_MIDI_SHORTMSG 0xB0|0|0x51|${outputmixer1volume}
I guess there is not much to understand within ProppFrexx, but more in general I guess ;-)
A midi short message typically has got 3-bytes:
1. byte: status and channel
2. byte: data1
3. byte: data2
As such the EXEC_SEND_MIDI_SHORTMSG let's you exactly compose the midi short message like that.
The 'only' thing you need to know is what your midi controller expects/accepts - but this is out of my scope as each controller uses its own...that's why I pointed you to the controllers manual.
However: What do you want to do?
Please describe this detail...
It looks like the Controller has a 'learn' function and you can define it yourself...?!
Yvetiboom
Post by Yvetiboom »
Haaa it's great works
Thank you very much for your help!
