Windows Taskbar Commands
Hey Bernd,
Not sure how difficult implementation on this one would be, but it would be nice to have a few basic control options on right clicking ProppFrexx's icon on the windows taskbar.
The most important one for me would be user access control switching.
Other ideas would be auto play, starting the scheduler, play/pause, etc.
Any possibility of something like this?
Best,
Louis
Best,
Louis
Re: Windows Taskbar Commands
Everything is possible
I'll think about it...
Unfortunately I discovered a memory-leak which is caused by the taskbar assistant feature (which was just added in v3.0.13.6).
This memory leak seems to be present in the taskbar assistant itself and is therefore out of my control (as its a Windows OS feature).
Therefore I removed this feature again, until the memory-leak is fix by either Microsoft or until I am finding a decent workaround!
It is therefore highly recommended to update to v3.0.13.12 due to the memory-leak being found!
