simple Playlist + jingle once in a while
mikedude
Post by mikedude » 13 Dec 2017 20:49
I want to create a music playlist but have no idea where to start, because of all the options.
Of course I can just drag music + jingles into a playlist (below the players), but how do I create a playlist where I (for example) can say:
1. play random tracks from folder x
2. play a jingle from folder x each 2-3 music files.
I just need a quick start so I can experiment.
I also noticed that some jingles fade to quickly, so I need to adjust Next and Fade somewhere.
thanks
Michel67
Re: simple Playlist + jingle once in a while
Post by Michel67 » 13 Dec 2017 20:57
I have become much wiser because of the explanation in the tutorial videos
http://www.proppfrexx.radio42.com/forum ... f=5&t=1018
good luck
Post by radio42 » 14 Dec 2017 08:36
The most simple way is to create a small script, which defines exactly what you are looking for.
Beside the tutorial videos given above, these two post might be on interest:
http://www.proppfrexx.radio42.com/forum ... p?f=9&t=10
http://www.proppfrexx.radio42.com/forum ... p?f=9&t=11
To insert a Jingle from a folder after every 2-3 music files; you can simply create a folder based cartwall library and then specify in the script-header to use that cartwall library as your 'Jingle' within a range of every 2-3 script-lines.
In your script-lines you then specify your regular music to be scheduled; eg. you for example use one or more media libraries and 'pick' tracks randomly from them for example.
mikedude
Post by mikedude » 17 Dec 2017 16:23
Thanks, I have looked at it, but it needs a bit more study I found out.
Would be great if a simple wizard could be made into Proppfrexx, who would ask some questions and would create it for you.
Post by radio42 » 17 Dec 2017 17:53
I guess such a wizard doesn’t really make much sense, as almost all users want something different.
Who is online
Users browsing this forum: No registered users and 16 guests
