Find track do not show
Post by hdradio » 26 Jun 2018 07:04
This morning I updated to v4.0.4.29
I clicked on Ribbon, View->Find Track:
The result is this:
Also - I am not very sure - but I think that the cpu usage is higher than the previous version.
Usually PFOA had about 5% but now it has 20% of cpu.
Re: Find track do not show
Post by hdradio » 26 Jun 2018 10:06
26/06/2018 07:23:39 [v4.0.4.29]:********** Error/Exception Information **********
Error Source: DevExpress.XtraTreeList.v18.1.Boolean IsColumnFieldNameSortExist(DevExpress.XtraTreeList.Columns.TreeListColumn)
   at DevExpress.XtraTreeList.TreeList.IsColumnFieldNameSortExist(TreeListColumn column)
   at DevExpress.XtraTreeList.TreeList.GetColumnFieldNameSort(TreeListColumn column)
   at DevExpress.XtraTreeList.Internal.TreeListFilterHelper.GetFilterValueType(TreeListColumn column)
   at DevExpress.XtraTreeList.Internal.TreeListFilterHelper.IsAllowAutoFilterConditionChange(RepositoryItem item, TreeListColumn column)
   at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.UpdateAutoFilterRowCellInfo(CellInfo cell)
   at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.UpdateBeforePaint(RowInfo ri, Boolean always)
   at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRow(TreeListDrawInfo e, RowInfo ri, Boolean isAutoFilterRow)
   at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRows()
   at DevExpress.XtraTreeList.Painter.TreeListPainter.DoDraw(TreeListViewInfo viewInfo, GraphicsCache cache)
   at DevExpress.XtraTreeList.TreeList.OnPaintCore(GraphicsCache cache, PaintEventArgs e)
   at DevExpress.XtraTreeList.TreeList.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at DevExpress.XtraEditors.Container.EditorContainer.WndProc(Message& m)
   at DevExpress.XtraTreeList.TreeList.WndProc(Message& m)
   at ProppFrexx.ProppFrexx_ONAIR.SRWz(Exception  )
   at ProppFrexx.ProppFrexx_ONAIR.JRWt(Exception  )
   at ProppFrexx.ProppFrexx_ONAIR.XRWV(Object  , ThreadExceptionEventArgs  )
   at System.Windows.Forms.SafeNativeMethods.UpdateWindow(HandleRef hWnd)
   at System.Windows.Forms.Control.Update()
   at DevExpress.XtraTreeList.Handler.TreeListHandler.TreeListControlState.GotFocus()
   at DevExpress.XtraTreeList.TreeList.OnGotFocus(EventArgs e)
   at System.Windows.Forms.Control.WmSetFocus(Message& m)
   at System.Windows.Forms.UnsafeNativeMethods.SetFocus(HandleRef hWnd)
   at System.Windows.Forms.ContainerControl.FocusActiveControlInternal()
   at System.Windows.Forms.ContainerControl.SetActiveControlInternal(Control value)
   at System.Windows.Forms.ContainerControl.set_ActiveControl(Control value)
   at System.Windows.Forms.Control.Select(Boolean directed, Boolean forward)
   at System.Windows.Forms.Control.SelectNextControl(Control ctl, Boolean forward, Boolean tabStopOnly, Boolean nested, Boolean wrap)
   at System.Windows.Forms.ContainerControl.Select(Boolean directed, Boolean forward)
   at DevExpress.XtraBars.Docking.ControlContainer.Activate()
   at DevExpress.XtraBars.Docking.DockPanel.OnActivate()
   at DevExpress.XtraBars.Docking.DockManager.OnActivePanelChanged(DockPanel newPanel, DockPanel oldPanel)
   at ProppFrexx.Docking.DockingHelper.ShowPanel(DockPanel panel, Boolean activate)
   at ProppFrexx.Docking.DockingHelper.ShowHidePanel(DockPanel panel, Boolean activate)
   at ProppFrexx.ProppFrexx_ONAIR.dRCP(Object  , ItemClickEventArgs  )
   at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
   at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
   at DevExpress.XtraBars.BarItemLink.OnLinkClick()
   at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
   at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
   at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
   at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnUnPressItem(DXMouseEventArgs e, RibbonHitInfo hitInfo)
   at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseUp(DXMouseEventArgs e)
   at DevExpress.XtraBars.Ribbon.Handler.RibbonHandler.OnMouseUp(DXMouseEventArgs e)
   at DevExpress.XtraBars.Ribbon.RibbonControl.OnMouseUp(MouseEventArgs e)
   at DevExpress.XtraBars.Ribbon.RibbonControl.WndProc(Message& m)
   at DevExpress.Utils.Drawing.Helpers.NativeMethods.UnsafeNativeMethods.DefSubclassProc(IntPtr hWnd, IntPtr Msg, IntPtr wParam, IntPtr lParam)
   at DevExpress.Utils.Drawing.Helpers.Win32SubclasserFactory.Win32Subclasser.SubClassProcInner(IntPtr hWnd, IntPtr Msg, IntPtr wParam, IntPtr lParam, IntPtr uIdSubclass, IntPtr dwRefData)
   at Nw.SQ.eotZ(String[]  )
********** End **********
Post by radio42 » 26 Jun 2018 19:35
Note, that the .29 is a beta version.
However, can you please send me the full "Error.log" file to get the full stack trace. The error looks like a migration issue inside the UI lib which I am using related to certain column sort conditions.
To resolve the issue, please close ProppFrexx and go to the ProppFrexx AppUserData folder and delete the file called "ProppFrexx ONAIR.Find.layout" file and than try again.
I cannot notice any increase in CPU usage here on my test systems. I have also just spoken to 2 other users for which this beta-version was targeted and they also did not notice any increase in CPU.
This is even expected, as only a very few and very specific features have been added and a new UI lib version was introduced.
Who is online
Users browsing this forum: No registered users and 30 guests
