Finding filename of current playing track using tcp command
phonic
Post by phonic » 22 May 2020 21:45
I’m trying obtain via TCP the Filename of the current playing track so I can identify the stream name(http://ipAdsress/studioName) I tried using ping ${filename) but it’s blank. I can’t use meta data(cpltracknamecurrent, etc) as they show the current title and artist as sent via the stream.
What command or macro would I use for this?
Re: Finding filename of current playing track using tcp command
Post by radio42 » 22 May 2020 21:56
I am afraid, that there is currently no macro to retrieve the filename and path of the current playing track!
Almost all meta data is available, but not the filename!
Why is a filename needed to be exposed to external systems?
phonic
Post by phonic » 22 May 2020 22:19
radio42 wrote:
22 May 2020 21:56
I need to know if it’s a stream and if so the name of the stream connected so the correct on-air notification can be set. Ideally, return the URL of the stream of current player(if it is a stream).
Post by radio42 » 23 May 2020 00:37
As said, there is currently no direct macro. But you can create your own :
In the Streaming.OnSongTitleChanged Event you can use the following command to store the last tracks filename:
EXEC_VAR_SET lastfile|${filename}
As this event is a track event you can use the ${filename} macro and store it’s content into a new variable called ‘lastfile’.
In your PING command you can now retrieve it back:
PING ${VAR:lastfile}
That should work as you need it.
phonic
Post by phonic » 23 May 2020 01:31
radio42 wrote:
23 May 2020 00:37
I'll give it a go. Thanks for your help!
phonic
Post by phonic » 23 May 2020 16:27
radio42 wrote:
23 May 2020 00:37
Worked fine, however to get next and now on-air stream info I set two new vars and used “ontrackload” and “ontitlechanged”. I was using “ontrackplay” but quickly noticed while News was playing filename VAR was not updated with the new track to be played and thus giving a false status.
works fine now... I hope 🤞
Who is online
Users browsing this forum: No registered users and 13 guests
