little Problem with Start Streamserver
Djharzerroller
Post by Djharzerroller »
If I want the stream server to start automatically. comes the message in the stream monitor
Title Update Error and the server does not start.
What could be the mistake?
Inzane8305
Re: little Problem with Start Streamserver
Post by Inzane8305 »
What server-profile are you using?
If Shoutcast : Have you downloaded the DNAS? Is it running ? The little program needs to run before.
This is also needed when using Icecast. (Serversoftware downloaded, installed and running after changes in config)
Hope this helps..
Regards Kjeld
Djharzerroller
I selected the streaming profile CBR mp3 128kps Stereo for the stream profile for Icecast and if I activate broadcast by hand, everything works and everything is displayed on the laut.fm page.
It does not work only when starting from a program or overlay program using a control command.
I entered the control commands in the program, in the stringing profile and in the event
Sorry for my English
Great Jörg
In order to also update the song titles (depends on the version and setup).
You might also need to provide your admin credentials in the streaming server config dialog within ProppFrexx.
Some servers also need/use a separate port address for sending title updates. Also this can be set in the same dialog.
And finally either remove or set the StreamID, depending on if this is a SHOUTcast v1 or v2 server.
And make sure you set the ‚Connect at Startup‘ option.
For detailed help on the options, please click on the ‚?‘ icon at the very top right to get help to all the options.
Djharzerroller
Hello Bernd
I don't want to start the stream server when I open Proppfrexx, but when an overlay scheduler entry starts.
If I start it by hand, it works. The title and program name are transferred.
I can't get the streamserver started with the commands
Greetings Jörg
Djharzerroller
The server does not disconnect with the server stop command
Please show the command you are using and where you are using them.
Either then never get triggered or the command is wrong.
But all these different questions doesn't fit to your first post?
Anyhow... seems you got all working except stopping them.
Djharzerroller
That's quite possible, my English is not that good and I just try the commands that might fit. It worked with the overlay programming and sometimes also with the normal program. It all starts on schedule.
Only I have not yet brought the normal program to a standstill. And as I mentioned before, I don't get a connection to the server start and server stop
And it all starts when I start Proppfrexx is not the solution
the command is
STREAMING_SERVER_START <radiot>
STREAMING_SERVER_STOPP <radiot>
registered in the program / stream server and at event
In the above commands you must provide your Streaming-Server names as a parameter.
E.g., if you configured streaming-server name is called "radiot", the command must be:
STREAMING_SERVER_START radiot
STREAMING_SERVER_STOPP radiot
I.e. remove the brackets.
Or you might use the STREAMING_SERVER_START/STOP_ALL commands (without any parameters) to start/stop all your servers.
Djharzerroller
The bracket was the problem, ok thanks Bernd. Most of the time they are just small things. But your software is really great. The Porsche and the radio programs and I'm a novice driver 8-)
Have a nice Weekend
Greetings Jörg
