Weather setup help needed
davefrmn2019
Post by davefrmn2019 »
Hi everyone,
I'm new using the software. I wanted to know how I go about setting up weather announcements with open weather ?
I have an open weather key.
Thanks.
gerritk
Re: Weather setup help needed
Post by gerritk »
davefrmn2019
Thanks but doesn't really go into details the steps needed to go though to add weather announcements. Also h.want to add an newscast feed I have in a url. What is the best way to add this to an top of hour schedule ?
Use that cast URL to be played. ProppFrexx not only plays local fipbut can also stream URLs.
Maybe you can give a more concrete example what you exactly you are looking for. For the weather announcements as well as the news/toth. ?
davefrmn2019
Thanks, Bernd, is it possible to change the time on display from 24 hours to 12 hours ?
Yes, just make a right-click on the clock.
