Find Track window
friso
Find Track window
Post by friso »
Hello
Everything has been working fine till now. If i want to searc in the find track windows it is finding nothing.
Can you tell me how the settings should be so i can search in all directorie and subdirectories and sub-sub directories.
My starting folder is "Music" underneath that there are all the other directories.
Thanx Friso
Re: Find Track window
Note, that the 'Find Window' searches within your defined Media Libraries and not within any other folders (except you have selected the 'Search also in Explorer Paths' - make a right-click in the Find-Window to check this).
As such you might define a 'Folder-based' Media Library for your main 'Music' folder.
Note, that it might take some time until that folder is completely rendered and read-in...
friso
Post by friso »
Thanx for the quick response
