PFOA stopped playing
Re: PFOA stopped playing
A few minutes ago PFOA stopped playing again.
When I realized that PFOA was not playing, I want to OnAir pc and I saw that a new playlist was created (for time 15:00), the previous playlist had stopped after playing the Time announce overlay at 15:00.
The DJ players were loaded instead.
I had to click F9 to start playing again.
I am a bit lost. What happened exactly?
At 15:00 a new playlist was about to start and a new playlist was created.
At that time the old playlist was of course playing before and was then of course stopped, because you also scheduled a Time Announcement as an overlay.
So the Time Announcement overlay did play correctly?
The new playlist had tracks loaded to their DJ Players?
Was the old playlist closed?
And as such was the new playlist not started?
You said you just wanted to go OnAir...so did you change anything, e.g. turned AutoPlay off?
I was in my office listening.
The playlist ending at 15:00 was playing.
At (about) 15:00 the song finished, the Time Announce played and then playback stopped (the next playlist did not start playing).
I went to onair studio to find what is going on and I saw:
The previous playlist (ending at 15:00) was still loaded but not playing (of course because the next one should play).
The new playlist (starting at 15:00) was also loaded in a new tab. I clicked on this (new) playlist tab and I saw that the first playlist tracks were loaded to dj players.
But the new playlist DID NOT START automatically as it should.
I then clicked F9, the new playlist started playing and the previous closed automatically.
Any debug log available to take a look at?
you have PM.
Look at:
26/08/2014 14:58:49: Overlay Player closed.
26/08/2014 14:59:45: PLS-PlayNext d1500 @ 26/08/2014 15:00:00.
About a minute silence. I was lucky being at the studio that time.
Yes, there was a bug introduced with the latest version.
The new v3.0.14.12 will fix that again!
radio42 wrote:Yes, there was a bug introduced with the latest version.
27/08/2014 19:32:31 [v3.0.14.11]:********** Error/Exception Information **********
Error Message: Collection was modified; enumeration operation may not execute.
Error Source: mscorlib.Boolean MoveNext()
   at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()
   at System.Windows.Forms.Application.ExitInternal()
   at System.Windows.Forms.Application.Exit(CancelEventArgs e)
   at ProppFrexx.df.g()
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
********** End **********
The above showed trying to update to this new version.
I continued though and updated ok.
Hmm, that bug seems to be an internal bug of the UI lib I am using and is unfortunately out of my control.
It should however only happen sometimes when closing/updating the application and is very uncritical.
DO NOT UPDATE TO THIS VERSION.
New playlist starts and play in parallel with the last playlist's song.
I restore to previous immediately.
Yes, gosh! I am sorry - that happens when you are not at your real desk and try to fix things just by code without real testing!
I am really sorry!
A new v3.0.14.13 is now available, which should fix the issue - hopefully finally!
