Will this Samson Midi Pad Work?
RedPanda
Post by RedPanda »
Would this midi pad work in ONAIR? Like I mean can I program the pads to perform certain functions, like starting next track, etc..
http://www.samsontech.com/samson/produc ... hite-md13/
Re: Will this Samson Midi Pad Work?
Looks like yes. Even though some features might not be useful with ProppFrexx, e.g. the velocity option might not be used with PF.
However I can not recommend any hardware here as I can not test compatibility with each.
RedPanda
Post by RedPanda »
Very true, I'm just looking for some type of button hardware or something I can use that would be easier to use than keyboard shortcuts. If the knobs on this Samson are programmable perhaps I can tell them to control something in ONAIR. Hmm..
Take a look to the Novation Launchpad products ... some users already use them effectively with ProppFrexx.
RedPanda
Post by RedPanda »
OK, thanks!
RedPanda
Post by RedPanda »
Well, I got a Steinberg CMC-PD for using with the CartWall. I managed to set it up so far on one bank with CartWall 2. It seems to work great. Still lots to figure out. Fun.
