2 tracks were playing together
Post by hdradio » 21 Jan 2018 19:10
I 'd like to report that today, without any reason, two tracks started playing together. This continued also with the next tracks until I stopped one of them and the playlist continued normally.
Re: 2 tracks were playing together
Post by radio42 » 21 Jan 2018 19:58
What exact version are you using?
And do you happen to have any Debug Log file to look at?
Post by hdradio » 22 Jan 2018 17:39
I am using 4.0.4.16
I PM you the debug log.
Look at 14:35
Post by radio42 » 27 Jan 2018 12:41
Hi, the new v4.0.4.18 should fix that issue.
Post by hdradio » 13 Nov 2018 20:23
I still have the same problem. Not very often but it happens.
I 'll send you the debug log to check it out.
Look at 20:35:44
A song starts together with a sweeper. When the sweeper ends the next song starts playing together with the first one.
I had to manualy stop one of the two.
Post by radio42 » 14 Nov 2018 00:26
Do you maybe also happen to have the related playlist file with it?
It would also be interesting to know what type of sweeper you used, as for example VO_... sweepers do play in parallel with the tracks. And if the cue-points of the surrounded tracks are by accident ‚badly‘ set, this might theoretically happen.
As such, it would also be great, if can also take a look at there 3 audio files:
- the 2 surrounded tracks
- the sweeper track
Many Thanks in advance!
Post by hdradio » 14 Nov 2018 07:32
As a sweeper I usually use a file and play it with VO transition.
But now I see that the script does not have a line with this kind of file.
I send you the files asked.
Post by radio42 » 14 Nov 2018 08:29
Thanks.
I am not sure what you mean when you say:
„...But now I see that the script does not have a line with this kind of file....“??
Post by hdradio » 14 Nov 2018 08:31
I mean that I don't have a script line with a file playing with VO transition.
Post by hdradio » 14 Nov 2018 10:04
20:35:44 jingle starts
20:35:44 song 1 starts playing
20:35.49 jingle ends
20:35:49 song 2 starts playing together with song 1.
20:36:XX (When I realized that the two songs were playing together - I don't remember the exact time) I dropped one of the 2 songs (I think song 1)
Who is online
Users browsing this forum: No registered users and 26 guests
