OGG streaming
OGG streaming
Is it possible to streaming OGG in quality mode (e.g. Q10) instead of VBR or CBR?
Re: OGG streaming
No, currently only CBR and VBR are possible to configure, but I can also add an option to use the QualityMode in a future release.
Re: OGG streaming
That would be great, because in quality mode we could stream at ~500kbps instead of 320.
Thank you in advance.
Re: OGG streaming
I have provided a v4.0.5.37-Beta (so "Check for Beta-Versions..." to update).
This contains a new encoder profile option for the OGG encoder to define a Quality-Mode instead of CBR/VBR.
Re: OGG streaming
Thanks for adding this option, I just tried it and unfortunately it streams in CBR 128kbps.
If I choose e.g. Q10 and save the profile, when I open it again, it's Q4 ~128kbps again.
Also checked the stream's icy stuff, what SAM sends to the server in quality mode is on the left side, and PFOA is on the right side also in quality mode.
Re: OGG streaming
Ah yes, I see. Will try to fix this soon!
Re: OGG streaming
Please try the new/official v4.0.5.38 update this should hopefully fix this issue!
Re: OGG streaming
Yep, it works perfectly now.
Thank you!
Thank you!
Re: OGG streaming
One more thing that I discovered now. It's not a big thing but I'll be very happy if you can fix it.
STREAMING_SETSONGTITLE2 Artist=David|Title=Test|Servername=Test
This command doesn't change the artist and title fields in the stream.
I haven't tried MP3 or any other formats, I'm using OGG.
Edit: I was wrong. It updates the informations but puts everything in the Title field of the stream. ("Cím" means Title)
Re: OGG streaming
I assume, that your are using an ICEcast server - correct?
And an ICEcast server only supports a single 'SongTitle' string to be updated (which is build according to your given songtitle format out of your given attributed - probably you used a format ${title} - ${artist}?).
When using a SHOUTcast v2 server on the other hand, each meta data field would be updated individually.
I am also not sure, what you expect AIMP (which is 'just' a media player) to display? - maybe this is an issue to discuss with these guys?
Who is online
Users browsing this forum: No registered users and 8 guests
