Artist/Title song name
djbony
Post by djbony » 13 Jun 2019 09:24
Hi Berndt,
in the new version of PFOA, the playlist shows artist and title from the imported playlist instead of loading data from the TAG. Why? Can I turn it off?
Thank you, Petr.
Re: Artist/Title song name
Post by radio42 » 13 Jun 2019 10:05
What do you mean by "...from the imported playlist"?
Do you mean by "imported playlist" an external log file which you import?
djbony
Post by djbony » 13 Jun 2019 10:35
Exactly
Post by radio42 » 13 Jun 2019 12:00
I just tested it here and the Artist should be taken from the original file, but the Title should be taken from the imported log file (as this provides the title - unless the log provides an empty title, in which case the title should be used from the original file).
What log format are you using? And is an overlay or program log?
djbony
Post by djbony » 14 Jun 2019 22:42
I use program log import from Powergold...
Until now the problem was not. The Playlist was displayed by Metadata.
djbony
Post by djbony » 18 Jun 2019 23:25
Some solution?
djbony
Post by djbony » 19 Jun 2019 00:33
mixpoints also doesn't fit after the last update ...
Post by radio42 » 19 Jun 2019 11:44
A v4.1.0.0-Beta is available (so please use "Check for Beta-Versions..." to update) - which should fix this issue.
djbony
Post by djbony » 19 Jun 2019 13:19
Works perfectly. Thank you.
Who is online
Users browsing this forum: No registered users and 9 guests
