silence detection not taking action if next song or url is also silent.
phonic
Post by phonic » 16 Jul 2019 14:19
If silence is found in a pre-record(presenter error), I've set silence detection to fade to the next item in the playlist and works well. However, if the next item is also dead like it's a url that's live but has no audio, or another bad audio recording, it will not take action and will continue playing silence. Is silence detection waiting for audio before it resets?
Re: silence detection not taking action if next song or url is also silent.
Post by radio42 » 16 Jul 2019 15:18
Yes, it does! Once silence is detected, it won’t detect silence again until there was ‚noise‘ detected.
Maybe I can for you add a ‚reset‘ command once you skipped to the next playlist item.
However, this will have to wait once I am back from vacation ;-)
phonic
Post by phonic » 16 Jul 2019 16:50
Thanks, that would solve the issue.
Enjoy your vacation.
phonic
Post by phonic » 24 Aug 2019 09:21
Any idea when this new option will be added?
Post by radio42 » 24 Aug 2019 09:58
It is still on the wish list. Hopefully to the next release I guess.
Post by radio42 » 28 Aug 2019 22:02
A new v4.1.3.1-update is available.
In this version you can use the MIXER_IN/OUTPUT_SILENCEDETECTION_ON command to also reset the silence detection.
E.g. when silence was already detected, it won't normally detect silence again. Using this command, you can reset it, so that silence would be detected again after the defined time and thus the OnSilence event will be raised again as well.
phonic
Post by phonic » 29 Aug 2019 22:33
radio42 wrote:
28 Aug 2019 22:02
Thanks, I will give it a try.
Who is online
Users browsing this forum: No registered users and 19 guests
