F.T.E. example help
jsonio
F.T.E. example help
Post by jsonio »
I would like to have your confirmation about my setting.
I have a FTE, soft playing at hh:15min:00sec
I want allow it to start :
- only at the end of a song, i don't want the song to be faded out early
- only 2 minutes max in advance
- only 'til 4 minutes late
- after 4 minutes, the FTE has to be skipped
Can you confirm the good parameter for this behaviour is :
Max delay : 0
Max early : 120
Max late : 0
Max remaining : 240
Thank you a lot.. in advance (max. early : 120),
jsonio
Re: F.T.E. example help
CORRECTED - please see my new post below...
Yes, your settings look correct!
Start Type: Soft
This enables the subsequent options.
Max. Remaining: 240
This setting will skip the FTE, if the remaining time of the current track is greater that 4 minutes; i.e. if the FTE would start later than 4 min.
Maximum Delay: 0
Disable this option and always play the track til its ends. (the Max. Remaining option is evaluated before!)
Max. Early: 120
Defines how early a track can start, in this case 2 min.
Max. Late: 0
If this value is set to 0 and the Maximum Delay is set to 0 we also always let the current track play til its end.
If this value is greater than 0, the FTE starts at latest this number of seconds late.
