ProppFrexx faders using external midi controller
phonic
Post by phonic »
I've setup an external mdi controller to control the ProppFrexx faders, all works fine expect the faders. I've tested using MIXER_OUTPUT_VOLUME_SET, MIXER_OUTPUT_VOLUME_CHANGE, butonly got this one working: MIXER_OUTPUT_VOLUME_SLIDE OUT1|${mididata2asvol} but with an annoying delay(even if general fader is set at "very fast" in settings).
What commend should I be using for external midi faders and can you give me an example please?
Thanks!
Re: ProppFrexx faders using external midi controller
The ..._SLIDE command of course uses a timer to slide the volume - hence the delay!
However, that command uses exactly the same as MIXER_OUTPUT_VOLUME_SET (which is the correct command to use)!
As such, if MIXER_OUTPUT_VOLUME_SLIDE is working, MIXER_OUTPUT_VOLUME_SET should work as well.
You probably have done some config error initially.
Here is command which should work:
MIXER_OUTPUT_VOLUME_SET OUT1|${mididata2asvol}
If you got further trouble, try to disable the 'Auto Pair MIDI Messages' option in the general settings - as some MIDI controls have issues with this.
phonic
Post by phonic »
Thanks for your reply Bernd.
I tested all including MIXER_OUTPUT_VOLUME_SET OUT1|${mididata2asvol} and
MIXER_OUTPUT_VOUME_CHANGE OUT1|${mididata2asvol} OUT1|${mididata2asvol}
For some reason only SLIDE seems to work. I've disabled the pair midi messages option. I'll take another look know I know the correct commend to see if I've missed anything while changing commands.
phonic
Post by phonic »
radio42 wrote: 10 May 2020 18:46 The ..._SLIDE command of course uses a timer to slide the volume - hence the delay!
My very silly mistake. Working fine now and real time as should. :D
Thanks again for your quick reply and help!
