script with not the same file.
Bninane2020
Post by Bninane2020 » 14 Aug 2020 20:05
Hi everybody,
I have one question about ProppFrexx.
I have the same broadcast name every day , but it's not the same file. How do you do for the scripts?
Thank you so much
Re: script with not the same file.
Post by radio42 » 15 Aug 2020 14:41
I am not what you mean by broadcasting name, so I guess you anyway within a script-line using the LoadTrack mode to reference a variable filename.
If that is the case, please take a look to the User Manual Appendix for the general or program macros.
You can use those macros in the script-line‘s entry column to specify a filename using these macros.
Example:
C:\Music\test${start_HH}.mp3
If the program‘s StartTime would be 15:00h, this macro would be resolved to:
C:\Music\test15.mp3
Hope you where looking for something like this.
Bninane2020
Post by Bninane2020 » 15 Aug 2020 16:41
Broadcast name is for example: Gaume Sweet Gaume.
Post by radio42 » 15 Aug 2020 16:50
And what has this broadcast name to do with a script or filename which is not the same?
Does my solution helped you out?!
If not please explain your issue in more detail.
Who is online
Users browsing this forum: No registered users and 19 guests
