when i go in the seque editor the start points dont update anymore
kevkev2001
Re: when i go in the seque editor the start points dont update anymore
Post by kevkev2001 »
is there any other solution to fix it i also Tried to reload al the Cue points also not working and also converted to sweeper
See 2 posts above...As I can not reproduce that here, can you send me the the three tracks in the example - plus one you saved (applied) the change in the segue-editor, can you also save the playlist and send that as well - to see, if I can reproduce that maybe with your tracks?! Thanks.
