Issue with Midi Controller - nanoKONTROL2
Re: Issue with Midi Controller - nanoKONTROL2
Good to here! So that sounds, like the MIDI controller somehow got stuck…
DjGuji
Post by DjGuji »
radio42 wrote: 12 Jun 2022 10:12 Good to here! So that sounds, like the MIDI controller somehow got stuck…
Would seem so and it affected other applications as well. Strange thing though is that is kind of locked up when i restored my ProppFrexx backup as well. I just recreated everything again.
Probably a pure coincident.
emmanoah
Post by emmanoah »
Korg nanoKONTROL2 is a compact-sized multi-function mixing control surface connected with your monitor. A single MIDI Out shA single MIDI Out should not be used to connect many synthesisers in a long daisy chain of MIDI cables. While MIDI recording and playback may be possible with this configuration, SysEx transfers are far more demanding on hardware and software. If necessary, utilize a MIDI Thru box so that your connections spread out from one point rather than in a lengthy line. Make sure you have enough MIDI Ins and Outs to maintain a maximum chain length of two or possibly three synths.
