scrips randomly
yourx
scrips randomly
Post by yourx »
Question how can i select scrips randomly
Greet Henry
Re: scrips randomly
I can only guess what you effectively mean (as your question is not really detailed), but I guess you want to select a random script for a program scheduler entry?
Each program has a single script associated. Ie. it is not possible to select a random script for a given program scheduler entry.
But you can (within a script) randomly select a media library or randomly select a track from any give media library.
In addition you can (within a script) also 'Execute' another script (the Count parameter of a script-line will define how many rows should be returned by that execution). When you specify the 'Ramdom' mode for the entire script, you can randomly select any script-line to use next.
But maybe you can explain what exactly you would like to achieve and why. I can then try to specify a fitting solution to your use-case.
yourx
Re: scrips randomly
Post by yourx »
Mini specials!
This is my script for one special.
Track 1: Announcement jingle (selected)
Track 2: random music track from category
Track 3: Jingle (selected)
Track 4: random music track from category
Track 5: Jingle (selected)
I want to randomly call and post this short script via Overlay scheduler
Re: scrips randomly
Same answer as above.
For a program or overlay you can not randomly select the script.
But you can use the Execute option as explained above - assuming all special script have 5 script-line use Count=5.
yourx
Re: scrips randomly
Post by yourx »
Thanks Bernd.
