audio drop
Radiostar929
audio drop
Post by Radiostar929 »
Hi Bernd How do you load in a 10 second audio drop and play it on command?
Re: audio drop
There are several ways. E.g. you can use the Standby-Player.
But directly via control-commands you can use e.g. the following commands (see the User Manual Appendix for details):
- EXEC_PLAY_FILE
Example: EXEC_PLAY_FILE C:\test\test.mp3|OUT
or
- EXEC_DIRECTPLAYER_CREATE
- EXEC_DIRECTPLAYER_PLAY, _PAUSE, _STOP
- EXEC_DIRECTPLAYER_FREE
Here is a sample command sequence:
1) Create the virtual direct player:
EXEC_DIRECTPLAYER_CREATE MyPlayer|C:\Test\test.pfp|OUT
2) Start playback:
EXEC_DIRECTPLAYER_PLAY MyPlayer
3) Stop and Free it:
EXEC_DIRECTPLAYER_STOP MyPlayer
EXEC_DIRECTPLAYER_FREE MyPlayer
Here is another use case: viewtopic.php?p=8933
